Major transmission problem 6l80
Old 07-16-2015, 10:09 PM
meadows's Avatar
Default Major transmission problem 6l80
This evening driving home the transmission started to act up. I stopped and shut it down. It started up fine but now I only have first and second gear.... And once it shifts to second it will abruptly downshift to first until I hold it for a minute. Does not have 345or6. Any help is appreciated thanks
Old 07-16-2015, 10:23 PM
FFDP's Avatar
It's possible it's an electronic issue. These 6L80's no longer use one way clutches, it's just a clutch to clutch system with the TCM controlling pretty much everything.
Do you still have a warranty??
Old 07-16-2015, 10:33 PM
meadows's Avatar
It just hit 20k
Old 07-17-2015, 12:27 AM
gonzo 6.2's Avatar
what year? 4x4 ? engine ? mods? any other info
Old 07-17-2015, 12:40 AM
Jake75's Avatar
try unplugging you battery for a few minutes...may sound stupid but i only had 1st gear and i stopped at the gas station unplugged the battery and it was back to normal...i was told it went into a safe mode
Old 07-17-2015, 08:32 AM
meadows's Avatar
2014 Sierra 5.3, stall tune gear lts
Old 07-17-2015, 09:14 AM
gonzo 6.2's Avatar
Modified yikes,how many miles on mods? has it been spot on till now ? Jake75 said disconnect battery for a bit,I agree.Next thing will be go see your tuner.It could have codes
Old 07-18-2015, 06:32 AM
gnasty1521's Avatar
In for updates
Old 07-18-2015, 01:57 PM
Jake75's Avatar
mine went into safe mode again last night at the track (stayed on 2 step too long) went down the 1/4 in 1st gear...got parked and disconnected battery everyting went back to normal.
Old 07-18-2015, 10:19 PM
gnasty1521's Avatar
Sorry to hi-jack, but you made 600/638 with heads/cam?
How is the transmission holding up to it?
Quick Reply: Major transmission problem 6l80
