LT1 HPFP and injectors larger than L83?
Old Jan 2, 2018 | 06:47 PM
Cam Only SS 1LE
Default LT1 HPFP and injectors larger than L83?
Can anyone confirm this?
Curious if the HPFP and injectors are larger on the LT1 than the 5.3L/L83 ones of if they are the same.
Thanks!
Old Jan 7, 2018 | 01:38 AM
ToNasty's Avatar
Thanks!
If you'e talkjing about the camaro or corvette motor then yes
Old Jan 7, 2018 | 02:48 AM
Cam Only SS 1LE
I am referring to the 16+ Camaro and 14+ Corvette...
And when you say "yes" - do you mean yes - it's bigger? or yes they're the same?
Old Jan 7, 2018 | 05:22 PM
ToNasty's Avatar
yes as in more flow I'm going to upgrade to the lt4 pump and injectors
Old Jan 7, 2018 | 08:00 PM
ZO6Ted's Avatar
99% sure the pump is the same and the injectors are larger from L83 to L86. Lt4 are larger on both still.
Old Mar 17, 2018 | 11:14 PM
Cam Only SS 1LE
If this is true then it's true that the LT1 injectors/pump are the same as the L83 - (as it's been confirmed elsewhere that L86 and LT1 are the same) - Which makes sense since the L86/L83/LT1 are the bulk motors (so it's cheaper to make the pump/injectors all the same) and the LT4 is lower volume so that'd be the only one getting an upgrade.
Just gotta find out about the in-tank pumps now
Old Mar 19, 2018 | 10:03 AM
MrJimi1121's Avatar
LT1/L83/L86 HPFP are the same.
As for injectors
L86 118.7lbs
L83 96.5
LT1 corvette 121.1
C7Z06 140.7
not sure on in tank pump
Old Mar 19, 2018 | 02:57 PM
Cam Only SS 1LE
As for injectors
L86 118.7lbs
L83 96.5
LT1 corvette 121.1
C7Z06 140.7
This is awesome info!
Where did you get this? Jw
Old Apr 26, 2024 | 04:49 PM
NickDchevy's Avatar
Registered User
Default Injectors
How did those injectors end up working for U I’m having some issues with my truck injectors and wanna put some LT4 injectors did you have to tune the truck after or change the high pressure fuel pump or even the one on the gas tank??
1K.260
Sep 10, 2013 09:50 AM
1ImperialSS
Aug 19, 2006 01:08 PM
BLACKND
Aug 18, 2005 04:28 PM
