Lowering the front for free?
I have a 2016 Sierra & was looking at Rough Country's 2-4 drop kit & all that is essentially done on the front is relocating the struts to the underside of the control arm. They do include a 1/4" plate, Im guessing to make it an even 2" drop, but could this be done without using the spacer plate? Ive already dropped the rear with 2" shackles & removed the blocks. looking to lower the front a lil & this seems to be a free way of doing so. Thanks!
Ran my truck like that for 11k miles with no issues, used some aircraft grade bolts they were about $40 shipped from.
www coastfab com
Never had an issue you will need to get some offset bushings for the upper control arms to get the alignment back in spec completely; without them it is close but not close enough for me.
I have a 6.2 4wd so the drop was more like 3-3/8.
www coastfab com
I had that kit as well, used "grade 9" bolts from fastenal, but ended up doing it right with spindles. I guess it was okay, I just didn't like the ride too much with factory struts when lowered. I believe I still have the bolts and the little brackets just sitting around somewhere.... If you want them, pay shipping and I'll send them your way. -that's if I still have them.
