Long tubes, no cat, GM Borla Touring
Decided to throw the old system back on because the xr1 was to much cruising around. It actually sounds a ton better than it did with the stock manifolds. I've gotta order a new cat and get some pipe so I can cut out the flapper (it's welded open currently) and get that welded up and then I think it'll be done. |
Sounds awesome! How’s the cab noise and drone? Is there much at all? I’m planning on doing the exact same thing to my 2010.
Just the sound of the engine through the headers. No drone from the exhaust.
Sounds good!!
I like you are trying different thing. You'll never have the thought "What if i did it this way..?" |
Just time and welding wire.
I've got a small amount right at 1700rpm under a heavy load I didn't notice before. Once I get a cat converter back on I'm sure it'll go away. Its still WAY better than the xr1 was even with a j-pipe.
Originally Posted by madmann26
(Post 5461099)
Originally Posted by Bgbldodge
(Post 5461095)
(Post 5461099)
I'll have to revise my previous statement and say there is drone at 80-85mph. It's not bad on flat ground but on a hill it can get irritating. Hopefully a cat will take the edge off. I'm removing the flapper today.
