dose the TC unlock when switching from V4 to V8?
Old Feb 6, 2018 | 02:46 PM
colekill's Avatar
KickinAssAndTakinNames
Default dose the TC unlock when switching from V4 to V8?
or is it my imagination? either way its annoying.
I assume its to smooth out the transition
Old Feb 6, 2018 | 10:20 PM
shupe's Avatar
Wouldn't doubt it. Believe it did with the gmt900 series. It's been too long and too many mods to run logs to verify.
Old Feb 7, 2018 | 10:25 AM
00pooterSS's Avatar
Doubtful. Be absolutely retarded if so because it would offset/negate the fuel savings of 4cyl mode.
If it did, you'd notice the RPM jump up and down a few hundred rpm or so when it engaged/disengaged. I haven't noticed it doing that.
If I get a few minutes today I'll datastream my truck and monitor the lock up. But my money is on no, that it does not.
Old Feb 7, 2018 | 12:55 PM
colekill's Avatar
I think it unlocks during the switch then locks back up after 5 seconds or so. i do get a rpm bump when it happens.
I'm pretty sure this is whats happening now, but now i wonder if its supposed to, does everyone else's truck do the same..?
Old Feb 7, 2018 | 01:16 PM
trxmxzx's Avatar
13 Second Truck Club
My 2015 does, when switching from v4 to v8 it’s pretty annoy I’d agree- only for a few seconds depending if cruise control is on and grade of road
Old Feb 7, 2018 | 02:37 PM
00pooterSS's Avatar
I read your post wrong. During switching, maybe, I can't say 100%. There are a couple of switch on/offs of the tcc that I wasn't sure what caused them, because I was watching for typical TCC operation, the cyl deactivation could very well have been it.
I will tell you that if you're familiar at all with how TCC used to work (up till mid 00's) things have drastically changed. I saw the same basic activity I just saw with my truck with a late 00's Cadillac CTS. They run the converter at just about all times.
I shot this video on the fly and since I read your post wrong I wasn't eagle eyed on the cyl deactivation/moment of activation deactivation and TCC.
I gave you a shoutout in the description
edit: watching the vid a little closer looks like it does switch on and off during the cyl activation.. I have been in a big hurry during filming this and since filming so I haven't had time to analyze it.
Old Feb 7, 2018 | 02:44 PM
00pooterSS's Avatar
at around 2:10 in the vid it switched to 4 cyl mode and there was a dip in the graph so it appears it did turn the tcc of during the 8 to 4 switch
97camaross
Nov 30, 2009 06:27 PM
Most Hated
Jun 30, 2009 06:04 AM
Torque_Wrench
Apr 7, 2006 02:18 PM
2500HD6.0
Sep 1, 2005 03:08 PM
