Did my first oil change on it myself today...
Old Jul 9, 2015 | 07:50 PM
Noah Burns's Avatar
Default Did my first oil change on it myself today...
couple thoughts...
first of all, compared to the 2008, the drain plug is in a much better location, filter is obviously exactly the same as before.
Drain plug is 15mm still
I used K&N 2011 oil filter and Mobil 1 0W20 oil it took somewhere between 8 and 9 quarts, I'd know for sure if I hadn't spilled a large amount down the side of the engine because of the only issue I have with the new setup.
The old LS engines had the filler neck coming out of the valve covers, elevated, at a 90* angle to the engine, etc etc... well the new one isn't any of those things, not to mention that it's tapered on the inside and the funnel that I had didn't fit worth a **** ( see that above mention of oil being spilled ... ) oh well, little kitty litter and some degreaser and pressure washing fixed all that.
This is the first time I've changed the oil on it myself, it's the first change since the last factory service for free at 24,000 miles, there's 29,875 on it now, and the first full synthetic also.
Those of you that are going to be doing your own maintenance once the factory free changes run out, do yourself a favor and get a flexible neck funnel and you'll be golden!
Old Sep 2, 2015 | 06:37 AM
weazleburger's Avatar
This is very true. Only issue was my normal funnel was a pain because of the angle. Just need a new one as you said and all will be well
Old Sep 2, 2015 | 12:49 PM
Noah Burns's Avatar
not having the filler neck like the older models did is a real pain in the ***... whoever made the decision to get rid of that deserves a chuck norris kick to the *****.
Old Sep 2, 2015 | 02:18 PM
colekill's Avatar
KickinAssAndTakinNames
i bought a enormous funnel at walmart the other day worked like a GD dream. can dump about 4 quarts in it at once, and i didn't spill a drop
Old Sep 2, 2015 | 09:36 PM
cheyenne383's Avatar
TOWN CRIER
It's to keep you from working on it... There's not even a drain plug on the German cars anymore, that's where it's headed. If they make it easy to maintain they can't get $80+ for a freakin LOF. When $8/hr goober fills it with a gun on a hose angle and restrictions aren't an issue... And the dealer makes their margins!
Old Sep 7, 2015 | 05:50 PM
Noah Burns's Avatar
I'll never pay a dealer to change my oil EVER!!!
Corvette454l88
Sep 1, 2016 01:24 AM
Mossyoakglock
Aug 28, 2015 12:49 PM
madmann26
14
Aug 28, 2015 07:15 AM
thewrx
Aug 12, 2015 08:28 PM
Suburban2500
Jul 19, 2015 04:50 PM
