anyone find what's causing those trucks to vibrate ?
#71
Well, that certainly puts things in a different light.
Get them to drop a tranny or engine in the rear of it while it's there and drive it.
What wheels/tires was the truck delivered with.
They shouldn't be making you jump thru hoops
#72
i won't be surprise or can't believe anyone with this trucks , the problems are there sometimes it's masked under another problems you have or it take time to appear
my truck do this method ( drive every day it will vibrate , parked for a day or two it will be smooth on every road after 15 minutes give or take a few it will start vibrating ,
some people may not have this problems for now but it will get there by time , people complain after 30-40-50k miles so you will believe in time .
vmax 1994 i know what it feel like but i won't do any thing to fix it , wait until someone figure it out that's what am going to do
#73
The truck came with the aluminum 18's and 265/65/18 SRA's which I have a set of currently again because of some trading. They were worse with the rear vibration as I think the stiffer 10 ply KO2's helped hold it from moving so much lol.
I am used to this BS...... it took 5 dealerships in different towns and about 10 visits to fix the a/c in my 2013 F150 that Ford even had a TSB for...... because no one wanted to do it lol.
I live where there is only 2 GM dealers close and they are owned by the same guy..... otherwise it's over an hour to the next closest or 2.5 hours to the selling dealer which I can't be bothered with. Nobody gives loaners or rentals or anything for people that live out of town..... great customer service. I can take my truck in to the selling dealer and if they had to keep it, then rent a car to go with on my dime..... good deal huh! I am glad I pay a lot less than most people because if I got this garbage treatment and paid closer to sticker I would be really pissed off haha. I just chock it up to being in oil trash Alberta..... but these guys are all hurting and thus the local dealer is night and day over how they were 2 years ago when the town was hopping from exploration.
#74
#75
Yours is the opposite of the unladen vibration I do feel with mine...... so that's a lot worse. I wouldn't want to sit and wait but I do know that lots of guys online have it. Oddly though.... I know around 20 people with these trucks and not one of them has a vibration of any kind... Maybe our roads are so terrible we just don't notice lol.
i don't think so lol , lets see what will happen am due to another visit to my dealer in the next 2 weeks .
#76
What rear end does your truck have? I had a 15 with the same mileage as yours that the pinion nut had backed off on twice first time at 500 miles, second at 25,000. it was a customers vehicle so not sure of a loaded vibration like youre describing, but it did have a vibration and a noise(obviously bearings were toast), when i rebuilt the rear end i did notice that there is almost no torque on the pinion nut before the crush sleeve compresses, had to replace the crush sleeve in it twice to get it right.... i probably over did it on the thread sealant hoping to help the situation....
#77
9.76". The useless one that has no aftermarket parts for it so forget about fun stuff like getting rid of the gov lock. I can pop my shaft and check but I would suspect it would vibrate more than just while loaded. The other guy might have an issue with that though.
#78
[QUOTE=Wolftrk99;5381274]What rear end does your truck have? I had a 15 with the same mileage as yours that the pinion nut had backed off on twice first time at 500 miles, second at 25,000./QUOTE]
What could be some other symptoms of this? I don't really have any vibration issues but there is some popping noises and it feels like something is binding while backing up with the wheel turned at full lock.
#79
Going to pick the truck up now.... just waiting for a cab. They road force balanced and no surprise the tires were fine as was the existing balance on them..... so they charged me $200 to do nothing. Well at least I got a new valve body in the trans lol.
#80
Talking to some of the guys at work, there are quite a few different vibrations going on with these trucks... Anything from mismachined ring gears to vlom/exhaust causing the vibrations...
FEED... What youre describing could definitely be a differential issue.... If your truck is 4wd it could also be a transfer case issue if youre driving around on dry pavemnt on a sunny day in auto.... Wheels binding on turns, clunking in gear, noise vibration... All could be symptoms of incorrect excessive backlash
