Any noticeable gains in MPG from anything you've tried? Headers?
89 octane and 91/93 octane would be able to run the same cruise timing, the octane does not matter as much at low loads.
Even when going for all out power, you likely will not feel the maybe 10-15hp difference in the butt dyno. DI engines can get away with less octane is some cases because the fuel is shot straight into the combustion chamber. It's not a lot of money per fill, maybe 6-8 dollars but just saying that octane isn't everything when the engine is stock.
93 octane costs roughly 8$ more a tank than 87, and $4 more than 89. No point in going 89 IMO. The additional MPG cancels out the additional cost. And even if 93 didn't do much better than 89, which it will, it's 6 points higher than 87 vs only 2, it's only $4 a tank, and it will will also cancel out.
ALL engines can run more timing at ALL times on higher octane.
Honestly I wanted a 6.2 truck but couldn't find any in the price range I wanted to pay so I'm gonna do a couple of things to the 5.3 to get it up to 6.2 ish power but make sure I don't **** away MPG while doing it.
That's what I was looking for. Did you have stock catback as well? I have zero plans to do a stall, this truck launches hard enough stock to satisfy what I want and I'll be pulling a boat, my 04 wouldn't spin a tire to save it's life, this one will spin both no problem and will get better with tune and LT's. I've ran stalls before and know all about the MPG woes with a big stall.
Mines all stock, that I can vouch for... mine gets the best on 87, in fact I’ll go as far as to say I can feel the power loss on 93. These DI motors are sensitive, mine runs better when it’s warmer outside also. I suspect the fuel atomizes better with higher charge temps.
All the complete opposite of my 04.
When I had my 2015 6.2 we tuned it. The power pick up was good and the afr was a lot more consistent but mileage never improved. Buddy tuned his 2014 5.3 truck and it's night and day for power... again mileage has not changed. Stock is pretty normal on these... the physics of a brick come into play.
Yes I tuned my 17 and it's just getting worse the more I do because the mods are not for gas mileage lol... not that I care anyway haha.
I will be honest that I have had at least a dozen tuned vehicles by different tuners and whatnot... not one got better economy after.
are you wanting good mileage to save money, or just for bragging rights? you need to look for bang for buck if it's about saving money.
any additional mileage that you MIGHT get with that 93 octane will not equate to an $8 saving per tank over 87 or 89.
it's like people thinking e85 is the answer. yes, it's cheaper up front, but you fill your tank nearly twice as often. where is the savings?
Either because I subconsciously drive different, or the tune had an impact, I picked up a consistent 2mpg after my last dyno run. I went from 10.5-11mpg city to a clean 13, and on the highway I moved from 13 to 15 unloaded.
Loaded I am still 8-9. It was like that stock.
Best it ever saw was 19mpg on the highway lol.
I have a gauge for that
Also keep in mind people lie, especially on the internet. Bragging about MPG is almost as bad as people bragging about HP
Giving the benefit of the doubt, they may just trust the cluster info instead of actually measuring from the pump and dividing range by that. Also need to verify speedometer is calibrated correctly to tire size.
