3" rear drop?
Old Mar 30, 2016 | 12:37 AM
62nalide's Avatar
Default 3" rear drop?
Anyone done a 3" leveled rear drop? Need input on what's been done or where can I get this. Thanks.
Old Mar 30, 2016 | 05:17 AM
Feed's Avatar
Remove 1" lift block and get some 2" drop shackles. http://www.belltech.com/products/shackle-kit-12869.html
You will run out of thread on the u bolts after removing the lift block. This kit includes some thick washers.
Old Mar 30, 2016 | 07:39 AM
adunphy's Avatar
Any idea what sort of modifications would need to be made to assassin bars that are already installed on the stock (no-drop) setup if I wanted to use these shackles to drop 2-3"?
Old Mar 30, 2016 | 07:49 AM
formula53's Avatar
I removed my blocks on my truck when I first got it and there was plenty of threads left on the u bolts.
Old Mar 30, 2016 | 08:33 AM
62nalide's Avatar
Originally Posted by Feed
Remove 1" lift block and get some 2" drop shackles. Belltech Sport Trucks and Muscle Cars
You have any pics?
Old Mar 30, 2016 | 10:03 AM
Vortec350ss's Avatar
3" sounds like a lot just to level it
Old Mar 30, 2016 | 10:12 AM
62nalide's Avatar
These new trucks are almost 3.75" higher out back seen people do 3" drops just can't find pics
Old Mar 30, 2016 | 10:34 AM
colekill's Avatar
KickinAssAndTakinNames
I pulled the blocks out of mine but noticed the other day there is now only about 3 or 4 inches to the bump stop. yard of mulch or a good size trailer and i might be riding on the stops now....
Old Mar 30, 2016 | 02:38 PM
Noah Burns's Avatar
2" shackles and removed block here also and it sits pretty damn close to level. Looks SO much better than stock.
I was also concerned about the loss of travel like colekill so I think I'm going to get some air bags for when I have to haul one of the race bikes around or something like that.
If you do it, go ahead and throw a hellwig or other sway bar on that bitch, handles so much better the way mines setup now versus stock!
Old Mar 30, 2016 | 07:47 PM
RedLS's Avatar
I went ahead and put shock extenders on mine to regain some travel from the shock. It also relocates the shock to be at a better working angle. I measured the shock before I installed the extenders, then after, I gained back 1 1/2" of travel. I only dropped the back 2 inches though.. Worth it in my eyes..
