2014 5.3L camshaft specs
Old 11-26-2014, 04:44 PM
cueball's Avatar
Default 2014 5.3L camshaft specs
Does anyone have or know the 2014 5.3L camshaft specs?
Iv'e search but can't find what I want.
I'm looking for the full specs on the cam, Like;
Valve Timing: .006
Duration: Intake - 260* Exhaust - 266*
Lobe Separation: 115*
Duration @ .050" Lift: Intake - 206* Exhaust - 212*
Intake Centerline: 111*
Lobe Lift: Intake - .302 Exhaust - .306
Valve Timing @ 0.006 Lift: Intake - .513 Exhaust - .52
Exhaust Closes -13 ATDC Opens 45 BBDC
Intake Opens -8 BTDC Closes 34 ABDC
Thank you.
Old 11-28-2014, 06:38 PM
ZO6Ted's Avatar
I'm curious about the cam and heads too. I understand the head design is awesome.
Old 12-30-2014, 02:20 PM
elir_mn's Avatar
Hello...This camshafts its used LS engine?
Old 12-31-2014, 02:25 PM
stroked 4.8L's Avatar
It's a totally new design engine elir_mn. Intake and exhaust valves have been reversed in the heads compared to LS engines, and it has a high pressure fuel pump lobe at the rear of the cam .
Camshaft
•Camshaft End Play
0.025–0.305 mm
0.001–0.012 in
•Camshaft Journal Diameter
54.99–55.015 mm
2.164–2.166 in
•Camshaft Bearing Diameter
55.063–55.088 mm
2.1678–2.1688 in
•Camshaft Journal-to-Bearing Clearance
0.048–0.098 mm
0.0002–0.0038 in
•Camshaft Journal Out-of-Round
0.006 mm
0.0002 in
•Camshaft Lobe Lift – Exhaust Non AFM
6.97 mm
0.2741 in
•Camshaft Lobe Lift – Exhaust AFM
7.10 mm
0.279 in
•Camshaft Lobe Lift – Intake Non AFM
7.08 mm
0.278 in
•Camshaft Lobe Lift – Intake AFM
7.21 mm
0.283 in
Fuel Pump Lobe Lift
5.70 mm
0.224 in
•Camshaft Runout – Measured at the Intermediate Journals
0.05 mm
0.002 in
Camshaft Position Actuator
•Range of Authority
62 degrees
•Park Position
7 degrees Advanced
Old 01-01-2015, 12:38 AM
cueball's Avatar
Thanks stroked,
Do you also have the lobe duration, lobe separation angle, and intake center line
parked at 7* advanced?
Thank you.
Old 01-01-2015, 09:22 PM
ZO6Ted's Avatar
1.7 or 1.8 rockers?
Old 01-02-2015, 03:14 PM
I know the LT1 has 1.8 rollers, give me a few minutes.
Old 01-02-2015, 03:23 PM
Default Finally
It took some in depth reading in the engine specs but here they are,
•Valve Lift – Exhaust Non AFM
12.500 mm
0.492 in
12.753 mm
0.502 in
•Valve Lift – Intake Non AFM
12.700 mm
0.499 in
12.953 mm
0.509 in
•Valves – Valve Seat Angle
45 degrees
•Valves – Valve Seat Runout
0.05 mm
0.002 in
•Valves – Valve Seat Width – Exhaust
2.52 mm
0.099 in
•Valves – Valve Seat Width – Intake
2.00 mm
0.078 in
•Valves – Valve Stem Diameter – Production
7.955–7.976 mm
0.313–0.314 in
•Valves – Valve Stem Diameter – Service
7.95 mm
0.313 in
•Valves – Valve Stem-to-Guide Clearance – Production – Exhaust
0.025–0.066 mm
0.001–0.0026 in
•Valves – Valve Stem-to-Guide Clearance – Service – Exhaust
0.093 mm
0.0037 in
•Valves – Valve Stem-to-Guide Clearance – Production – Intake
0.025–0.066 mm
0.001–0.0026 in
•Valves – Valve Stem-to-Guide Clearance – Service – Intake
0.093 mm
0.0037 in
•Valves – Valve Stem Height – Measured from Spring Seat – Intake and Exhaust
51.715–52.465 mm
2.036–2.065 in
•Rocker Arms – Valve Rocker Arm Ratio
1.80:1
Old 01-02-2015, 03:27 PM
I have looked at the specs but cannot find cam duration. sorry. I will post the complete specs that I have available if anyone wants me too.
Old 01-03-2015, 03:41 PM
meadows's Avatar
well its not like my truck will stay stock (it isn't now) for long. in for duration and LSA plz.
Quick Reply: 2014 5.3L camshaft specs
