Wrong cam Core!!!!
#21
Im sure you could probably swap phasers and tune accordingly. Might be your easiest and cheapest solution, just saying....
It is a pain that you have the wrong core for sure but Im pretty sure you could simply do this. if you put a wanted ad up over on tech for the correct phaser ( maybe ecm too? ) for the one matched to your core theres lots of guys watching who will probably have what you need for cheap. not many people mess with VVT so theres a lot of available parts.
What valve springs are you running? Whats the cam specs?
#22
Thanks for the suggestion, that is a great idea. I've already got all of the parts on the way to delete these. Now i just need to get the cam replaced.
I'm running some performance valve springs from comp. p/n 26915-16. They're good for up to about a 560 lift which is what I'll go with the new cam.
#25
#27
im installing a comp vvt/dod cam with my 1.8 yella terra rockers it will put my lift at 536. my cam # is 689-421-13.with 5460 phaser limiter. and blue ls6 springs.
#28
My specs are going to be a 222/224 112 duration with .566 intake lift and .568 lift on the exhaust side.
