traction ,stabilitrak,ABS after rear shoock replaced
Old Jul 12, 2011 | 04:02 PM
wot_denali's Avatar
Default traction ,stabilitrak,ABS after rear shoock replaced
Dears,yesterday i replaced the rear autoride shocks with a similar one after the change abs traction and stabilitrak appears everything were correct the sensor and the copressor fitting were pluged what was wrong?
Old Jul 12, 2011 | 04:20 PM
Robert91RS's Avatar
1st) what do you mean you replaced it with something similar?
2nd) what prompted you to replace it?
3rd) is the compressor working and pumping up the new shock?
Old Jul 12, 2011 | 04:37 PM
wot_denali's Avatar
1-similar means new ,
2-why the old is not working
3-compressor is working
Old Jul 12, 2011 | 05:04 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Was anything else done on the vehicle? Different wheels/tires?
I'd re-check everything on the installation. Something may have been knocked loose, to a wheel speed sensor, or something next to the shocks.
Old Jul 12, 2011 | 05:09 PM
Robert91RS's Avatar
Document ID: 1871923
Installation Procedure
Install the shock absorber (5).
Install the upper shock absorber nut (1) and the bolt (2).
Notice: Refer to Fastener Notice in the Preface section.
Install the lower shock absorber nut (6) and bolt (7).
Tighten
Tighten the upper and lower shock absorber nuts (1) and (5) to 115 N·m (85 lb ft).
Reconnect the electronic suspension control connector, if equipped (3).
Reconnect the air line (4), if equipped.
Remove the support from the rear axle.
Lower the vehicle.
If the vehicle is equipped with air leveling, perform the following:
• Turn the ignition ON, with the engine OFF.
• Install a scan tool.
• With the scan tool, operate the air compressor for 30 seconds or until rear of the vehicle begins to rise.
• Remove the scan tool.
• Cycle the ignition OFF, then back ON, with the engine ON to allow the air suspension system to regain the desired rear suspension position.
Was the vehicle level when you started it back up? If so, the compressor may have thrown a code because it took too long to reach ride height without being able to manualy cycle the compressor using a tech2. I'd try reseting the computer in that instance.
Old Jul 12, 2011 | 07:29 PM
gnasty1521's Avatar
Way to pull out the GM books!!! Hopefully this helps.
Old Jul 13, 2011 | 01:26 PM
supercharged680's Avatar
hey bro.. long time! i would check the autoride sensor, are u getting a "service suspension system" warning.. , i would also check for a blown fuse, ive seen it happen a few times
Old Jul 13, 2011 | 04:38 PM
wot_denali's Avatar
Ok today i went under the car and i found unpluged wire at the rear between the spare tire and the catback but i did not found the place that this wire should be plug in .
Attached Thumbnails traction ,stabilitrak,ABS after rear shoock replaced-140720111412.jpg
Old Jul 13, 2011 | 08:46 PM
Robert91RS's Avatar
Its hard to make heads or tails of that pic but I would bet its either a ride height sensor or wheel speed sensor connector.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
Gadgetized
Aug 21, 2020 03:14 PM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
thewrx
Aug 12, 2015 08:28 PM
