TPS tap causing REP
Old Sep 17, 2016 | 01:40 AM
GM1697's Avatar
Default TPS tap causing REP
Tapped the purple wire at the TB for TPS signal for NX window switch. Truck goes into REP after driving for a few mins. Unplug my tap and the truck drives fine. How do I get around this. I need TPS for nitrous. Anyone have similar issues??
Old Sep 20, 2016 | 04:58 PM
musclecity85's Avatar
try the green wire..i think thats where i went on my. have you tried probing it with a multimeter to check the voltage at rest and wot?
Old Sep 20, 2016 | 06:12 PM
Three6GMC's Avatar
Idk if the controller is the issue with yours but that NX controller did the same **** on a 2014 Denali I just put nitrous on. Swapped out to a NOS controller and didn't have that problem again.
Old Sep 20, 2016 | 11:37 PM
1FastBrick's Avatar
Custm2500's Rude Friend
How close to the Tb is the tap?
Is it possible that you compromised the wire?
13chevy370
Sep 18, 2016 12:12 PM
r44guy
Sep 18, 2016 12:08 AM
Schiavonske1013
Sep 15, 2016 05:25 PM
Blackrat48
Sep 14, 2016 09:35 PM
TAPyvehc93
Sep 12, 2016 02:24 AM
