reluctor wheel
Old Nov 29, 2012 | 02:16 AM
maze2525's Avatar
Default reluctor wheel
How hard is it to change one? I have a 408 that was built to go in my 05 but now have a 2012that I'm wanting to put it in. Lingenefelter has a box to go from 58 to 24 but not the other way around. I spoke with them and they said they had on in the making but not ready yet. Guess my question is should I just wait for them or just change the wheel. And other then a knock sensor extension is their anything else I'll have to do to make this work.
Old Dec 1, 2012 | 08:41 PM
1FastBrick's Avatar
Custm2500's Rude Friend
The crank has to be completely removed in order to change the wheel. You will also need a tool like the one Goodson sells. You will need to use a little heat to remove the old ring and install the new ring. You should check it for run out before installing back into the engine to make sure its on straight. A New reluctor ring can be had through any GM dealer. They run around $30
#12559353 -24x Reluctor wheel
#12586768 -58x Reluctor wheel
Goodson tool is RRJ-350
GOODSON : Crankshaft Work : Reluctor Ring Jig
sprayed99
Sep 21, 2015 04:47 PM
George C....
Sep 11, 2015 04:45 PM
03chevytruck
Sep 10, 2015 10:18 PM
Forcefed81
Sep 8, 2015 10:02 PM
the owl
Sep 4, 2015 04:09 PM
