Radiator upgrade in 07 GMT900?
Old Nov 30, 2014 | 08:11 PM
Gray Ghost Silverado's Avatar
Default Radiator upgrade in 07 GMT900?
Hey guys, I'm looking for an upgraded radiator for my truck. It was a Max Trailoring Package 6.0 from the factory. Anyways, with the addition of the 428 iron LSX, it runs a little on the warm side on a hot summer day with the A/C on (220 at idle ~200 at cruise) I understand that's fine, but for a race motor it doesn't seem quite right. When its just a little cooler outside under 100 degrees it runs 190 at idle and 183 at cruise which is just right. Fans run just as they should. So I need a more efficient radiator to install. It can't be any wider physically than it is now because the inlet of the turbo is crammed between the light bezel and end cap, but it can be a little bit thicker, or the same thickness as the endcaps with another cooling row inbetween. Can't go too thick or it'll move the fans too close to the hot pipes.
What should I do?
Thanks in advance.
Old Dec 1, 2014 | 12:30 AM
Iconic Motorsports
maybe try becool additive
Old Dec 1, 2014 | 09:42 AM
GMCtrk's Avatar
Change the thermostat
TrickTurbo
Sep 23, 2015 08:41 PM
elir_mn
Sep 19, 2015 11:43 AM
99bluefirebird
Sep 17, 2015 08:05 PM
Noah Burns
Sep 13, 2015 09:28 AM
