Radiator Trans Cooler Line Fittings
Old Jul 9, 2013 | 02:05 PM
shupe's Avatar
Default Radiator Trans Cooler Line Fittings
I’m in the process of converting the factory lines over to stainless braided with AN fittings and have the correct fitting for the 4l8E and the tru-cool however the 5/8x 18 I’ve found referenced in other threads will not thread into the radiator. What have you guys found to work?
Old Jul 9, 2013 | 02:55 PM
Gus 82's Avatar
It should be a -6 straight thread but there is a catch. The factory fittings have that cone shaped washer, which pulls the trans cooler to the radiator end tank can creates a seal. If you do not use a fitting that does not have the cone shape washer the cooler will " push" into the end tank and engine coolant will pour onto the floor. Dont ask how I know.
Old Jul 9, 2013 | 04:35 PM
javzh's Avatar
on the radiator i used fittings from pure choice motorsports that clipped right into the stock factory fitting.
worked perfect.
Old Jul 9, 2013 | 08:00 PM
shupe's Avatar
No doubt. I was thoroughly confused for as second when it sprayed on the intake and down the radiator. Did you find a proper fitting to replace the factory cone shaped washer e clipped haydapter deal?
worked perfect.
Really don't like the e clips but if its the only option guess it'll work. Looked on the site and didn't see em. Do you know the part number?
-Shupe
Old Jul 9, 2013 | 08:23 PM
Gus 82's Avatar
I have not. I did the old Tube nut and sleeve on the hard line. Not a fan of it. I heard Jiffy Tite was the oem supplier of the fittings but I havent found one with the washer.
Old Jul 9, 2013 | 09:18 PM
javzh's Avatar
-Shupe
part number 12055.
i would post a link but forum but the forum rules forbid non vendor links.
i have these on my turboed rcsb no problems so far.
Old Jul 10, 2013 | 08:41 AM
shupe's Avatar
Right on. I'll contact them when they open and place the order.
Appreciate the help.
ullose272
Aug 5, 2016 02:05 PM
bighouse
Sep 27, 2015 12:37 AM
1slwgto
Aug 16, 2015 06:40 PM
Ls3silverado
Jul 31, 2015 04:22 PM
ferrellrooster
Jul 17, 2015 07:07 AM
