Radiator Trans Cooler Line Fittings
I’m in the process of converting the factory lines over to stainless braided with AN fittings and have the correct fitting for the 4l8E and the tru-cool however the 5/8x 18 I’ve found referenced in other threads will not thread into the radiator. What have you guys found to work?
It should be a -6 straight thread but there is a catch. The factory fittings have that cone shaped washer, which pulls the trans cooler to the radiator end tank can creates a seal. If you do not use a fitting that does not have the cone shape washer the cooler will " push" into the end tank and engine coolant will pour onto the floor. Dont ask how I know.
on the radiator i used fittings from pure choice motorsports that clipped right into the stock factory fitting.
worked perfect. http://www.purechoicemotorsports.com...prd_zm_177.jpg |
Originally Posted by Gus 82
(Post 5122776)
Originally Posted by javzh
(Post 5122810)
worked perfect. -Shupe |
I have not. I did the old Tube nut and sleeve on the hard line. Not a fan of it. I heard Jiffy Tite was the oem supplier of the fittings but I havent found one with the washer.
Originally Posted by shupe
(Post 5122921)
Really don't like the e clips but if its the only option guess it'll work. Looked on the site and didn't see em. Do you know the part number? -Shupe i would post a link but forum but the forum rules forbid non vendor links. i have these on my turboed rcsb no problems so far. |
Right on. I'll contact them when they open and place the order.
Appreciate the help. |
