oil pan relief valve?
1 Attachment(s)
What is this, what does it do and why is it there? It sits right above the oil filter inside the oil pan. Its off a 08 LY6.
Attachment 108552 |
your not kidding calling it a relief, sure looks like it!
I wouldnt think it'd be for the oil filter cause that has its own relief, but maybe its for the lines, in the event the cooler gets clogged or the line gets pinched maybe whats above it in the block? |
Theres nothing above it just regular engine internals. Can it be removed and plugged? The older oil pans didnt have this.
2 Attachment(s)
Originally Posted by RS/SS 4.8
(Post 5164759)
Attachment 108541 Attachment 108542 |
That valve vents pressure for the AFM lifters.
Originally Posted by Preston129
(Post 5164859)
Note it’s also included in some non-AFM combinations, likely owing to hardware deproliferation edicts. But who here hasn’t deactivated cylinder deactivation? :D |
Splinter and Preston have pretty well answer your question but I thought it may be worth mentioning that valve has been known to spray so much oil on the cylinder 7 walls it can actually gunk up the piston rings and drop compression. GM has a bulletin and even pruduced a sheet metal hood that fits over it and helps direct the spray away from the cyl walls. Just another reason to hate AFM.
Lol I just found that bulletin on the Alldata at the shop yesterday. The G8 GT I have also has this crap and as soon as I can do a dod delete ill cap that relief valve on it as well. Thanks guys.
Now on another note, does anybody know what thread pitch is on this thing. It looks almost like a AN fitting and none of the regular parts store fittings ive found seem to match.
| All times are GMT -5. The time now is 01:28 AM. |
