NNBS Variable Voltage Fuel Pumps??
Old Mar 15, 2011 | 02:32 PM
carbongmc's Avatar
Default NNBS Variable Voltage Fuel Pumps??
So, I go yesterday to buy my walbro 255 pump from my buddy that owns Lightning Motorsports in Baton Rouge. He asks me what vehilce im putting it in and I say 09 GMC CC. He calls his friend who is one of the engineers at Walbro, and this guy says we have a variable voltage pump system on our trucks and their pump wont work unless its hard wired in. Is this true? Im trying to get my fuel system done before my turbo kit comes in and Im trying to see if I will need to do a return style system with this pump and hard wire it in or not. I would rather not for the time being. Anyone got any info on this or if this is true??
Old Mar 15, 2011 | 02:49 PM
smokeshow's Avatar
Mod with training wheels
Yes, he is correct, you will not be able to use that pump on the stock fuel system. I've tried it lol... What are the specs on your setup? The stock pump is pretty strong. I'm still running the stock pump and fuel lines, and I see a bit of a pressure drop at WOT but haven't gone lean yet. The new operating systems on the GMT900s its very versatile is far as fueling is concerned.
Old Mar 15, 2011 | 03:08 PM
carbongmc's Avatar
Im going to be running a Trick front mount Non-Intercooled kit, and a LS2 cam with 60lb injectors. Will the stocker be enough to keep up for a while with the 60s?
Old Mar 15, 2011 | 03:10 PM
smokeshow's Avatar
He only recommends running his intercooled kits up to about 7psi because of the high IAT issue, so at that boost level you'll be fine with the stock pump.
Old Mar 15, 2011 | 04:08 PM
carbongmc's Avatar
well thats good news then. that just cut out alot of extra work i was thinking would need to be done before i put the kit on. upgrading the fuel pump and system can wait until i get the front mount for the kit later on. Thanks for the info man!!
Old Mar 15, 2011 | 07:05 PM
cam's Avatar
cam
Its a bit late and im still working but having a beer or three so if im worng dont shoot me.
That said it has something to do with the flexfuel ethanol capacity. Ethanol requires a LOT more fuel volume than gasoline so the fuel pumps are variable for this reason. The good news is they do flow a boat load of fuel so yeah sounds like your okay with the stocker. At least i think thats how it is
Dunno for sure... getting old...er sucks
slowlsx
Aug 13, 2015 08:28 PM
05GMC4.8
Aug 7, 2015 09:55 PM
RS/SS 4.8
Aug 2, 2015 11:03 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
