NNBS RCSB Power Window Conversion
Anyone do a power window conversion in an NNBS? I have found a few good deals on some NNBS Regular Cab Trucks, but most of them have manual windows and locks. I would want to swap out the door panels for a factory look. Just wanted to know if anyone has done the swap, and if it required any BCM programming or anything else. Thanks
Depends on what direction you are trying to go. If you go the LTZ door panel route you wont need to change the dash harness because the door modules are serial data. But you have to go to a uplevel bcm, door panels, mirrors etc.
If you go normal silverado route I'm 99 percent sure you gotta change the dash harness and then find door harness for both doors regardless
