NNBS Lowering Questions answered here
Old May 11, 2015 | 01:17 PM
  #81
Troy Waguespack's Avatar
Default Bottoming out
I have 3/4 drop on my 07 Avalanche w/o autoride.
I have belltech drop springs and lowered shocks in rear. I did the free travel mod as well. I bottom out at times..but don't think I'm hitting the metal from the free travel mod.
I have a set of shock extenders I haven't installed. .. Should I?
I also replacing the current Belltech shocks with the stiffer version.
Suggestions. .. help??
Thanks
Old May 11, 2015 | 05:07 PM
  #82
TheSuspensionSource's Avatar
FormerVendor
Thanks
With that size drop you need extenders and shorter shocks. I would recommend the Street Performance shocks
Old May 11, 2015 | 05:40 PM
  #83
Those are the shocks I have to replace the one on there now.
So the bottoming out is the shocks bottoming out you think?
The Street performance shocks won't affect ride height will it?
Thanks.
Old May 12, 2015 | 10:16 AM
  #84
FormerVendor
Thanks.
Not having the correct part number would cause this and not using the extenders would also cause this.
The shocks do not play a role in your ride height.
Old Jul 8, 2015 | 04:21 PM
  #85
Tig's Avatar
Tig
I miss being low, my 99 2dr had a 5/7. Now, I have an 07 PPV, they come with a 2" drop. Tires are 275/60/17.
I have a 5" gap up front and a 6" gap out back. I would like to close that up without sacrificing ride quality, it handles well for a 5300lb+ vehicle.
What are your thoughts?
Any info would be appreciated.
Thanks
Old Jul 8, 2015 | 04:59 PM
  #86
FormerVendor
Thanks
I am not too familiar with the PPV model. Do you know which components these models come with the achieve the 2" of drop?
Old Jul 8, 2015 | 05:27 PM
  #87
Tig's Avatar
Tig
Don't quote me on this, hah but from the research I've done, they used Pedders Suspension system.
https://www.peddersusa.com/product/GMT-STREET-1-PKG
Old Jul 9, 2015 | 12:29 PM
  #88
FormerVendor
Seems like it is only a front 2" spring?
Old Jul 9, 2015 | 12:38 PM
  #89
Tig's Avatar
Tig
I believe its both front and rear 2" drop coils.
Old Jul 9, 2015 | 02:24 PM
  #90
FormerVendor
You could swap the rear coils for 4" springs and add a lowering strut to the front.
$130 for springs that includes shock extenders and front struts $190.
