NNBS Lowering Questions answered here
Old Oct 17, 2014 | 11:25 PM
  #51
signguy62's Avatar
Default Lowering a 4x4
I have owned a lowered 02 ExCab 2wd and an 05 Trailblazer 2wd. Both lowered 2/4 using Beltech kit on one and DJM kit on the other. But they were both 2wd.
Now I have a 2000 RCSB 4x4 that I want to lower and I've never messed with torsion keys so I'm a little intimidated. What do you recomend for lowering it? If I just remove the rear blocks and un-crank the keys where would I be? Any info/suggestions would be greatly appreciated.
Thanks!
Old Oct 18, 2014 | 12:07 AM
  #52
FFDP's Avatar
Maybe a 1/1 drop?
The block is only like 1in thick I think. I would remove the block, do a 2in drop shackle and you'd be at roughly 3in in the rear and just do drop spindles up front to get 2in. That should keep everything up front good with the cv axles.
Old Oct 18, 2014 | 07:42 PM
  #53
signguy62's Avatar
Thanks FFDP! Hey, can the keys be backed off some with the spindles? Isn't it the keys cranked up that causes the harshness in the front end?
Old Oct 19, 2014 | 12:26 AM
  #54
FFDP's Avatar
I'm sure you could back them off but not sure you'd need too.
And yeah having them cranked up can cause poor ride quality. They cranked them up on our shop truck (1500 HD) to give it more room for the tires and it rides like complete *** around town.
Old Oct 19, 2014 | 04:20 PM
  #55
TheSuspensionSource's Avatar
FormerVendor
Thanks!
I would just toss a 2" drop spindle in the front and use a shackle/hanger kit for 4" in the rear.
Old Oct 19, 2014 | 04:21 PM
  #56
FormerVendor
Messing around with Torsion bars can give you some nasty camber problems.
Old Oct 27, 2014 | 11:42 PM
  #57
1CL3ANSUP3RSPORT's Avatar
Originally Posted by TheSuspensionSource
If you have the tools and patience then the job can be done within your home garage.
I would go with the Belltech Part#2511 spindle, Belltech Struts with the Belltech 5" to 6" Flip kit, Part #6521. Also will need rear shocks, Part # 2210FF.
Can I get a price on this please!
Old Oct 28, 2014 | 11:58 AM
  #58
FormerVendor
Belltech Part#2511 spindle $278
Belltech Struts 25003 $75x2= $150 (blemished paint)
Belltech 5" to 6" Flip kit Part #6521 $284
Part # 2210FF $59.20x2= $118.40
w/ forum discount of 10% $747.36
plus free shipping, that saves you about $50-$75
Old Oct 28, 2014 | 04:29 PM
  #59
Thank you for the response!!!
Old Oct 29, 2014 | 04:08 PM
  #60
musclecity85's Avatar
Originally Posted by Blewis09
Will I be able to use it at all?
yes your 4wd will still be useable. i have an 08 silverado z71 4x4 and im lowered 4/7. 4wd works just a it did as stock height.
