NNBS Lowering Questions answered here
Old Jan 8, 2016 | 04:39 PM
  #101
RS/SS 4.8's Avatar
10 Second Truck Club
Belltec sells offset bushings and alignment plates. I have the bushings only with the belltechs first spindle design and its right on the acceptable side of specs but with the milage ive put on it the tires show no irregular wear. 4/7 btw
Old Jan 8, 2016 | 08:46 PM
  #102
Feed's Avatar
I would also recommend the bushings. Easier than grinding out the upper control arm bolt slots imo.
Old Jan 9, 2016 | 09:54 AM
  #103
chopperloco's Avatar
Thanks men!!
Old Jan 10, 2016 | 08:43 PM
  #104
Tig's Avatar
Tig
At what point do you need to use the alignment bushings or plates or both?
Old Jan 10, 2016 | 09:37 PM
  #105
FFDP's Avatar
When you are out of range with the stock camber/caster adjustments.
Or likely more than 2in front drop depending on how you are lowering it.
Old Jan 11, 2016 | 03:44 PM
  #106
Tig's Avatar
Tig
I have 2" drop coils now. I have Bell Tech struts and was considering getting some spindles.
I'd keep the struts at zero and use the coils and spindles for a 4" drop.
Should I just get both plates and bushings to be on the safe side?
Thanks
Old Jan 11, 2016 | 07:00 PM
  #107
Feed's Avatar
Thanks
Every truck is a little different but i would get the 2511 spindles and the offset bushings and go from there.
Old Jan 12, 2016 | 02:31 PM
  #108
Tig's Avatar
Tig
Ok cool.
Do you happen to have a part number for the offset bushings?
Thanks
Old Jan 15, 2016 | 07:42 PM
  #109
Ok cool.
Thanks
your google broke?lol
Belltech Alignment Kits Belltech Sport Trucks and Muscle Cars
Old Jan 15, 2016 | 07:53 PM
  #110
Tig's Avatar
Tig
Originally Posted by chopperloco
Thanks
