NNBS hesitating to start after removing gas cap
Old Jan 20, 2015 | 10:21 PM
cams 98 silverado's Avatar
Default NNBS hesitating to start after removing gas cap
Hello all,
So this issue of mine has started about 2 months ago. truck is an 07 NNBS 5.3 LY5
I turn the truck off and remove the gas cap. I proceed to pump fuel into the tank and then put the gas cap back on, get in and first attempt the truck fires then turns right off not even getting 2 revolutions. Try to start again and it tries to turn over but after 5 sec of the starter turning and intermittent fires it finally fires up and runs fine.
The truck acts like theres a vacuum leak but once it creates vacuum it works just fine.
I have no codes when this happens and no pending either. Last year I got a P0442 which is a small evap leak. I replaced the solenoid under the truck and the valve at the engine. I still randomly get the small evap leak code but it can be a few weeks between the times i get it and there is no repetitive code set after getting gas. It also does not matter if I fill up, or get half a tank.
My only other thought is the map/pressure sensor on the tank not functioning right and not telling the ECM that the tank has been recently vented and when I go to start the truck, the engine pulls a vacuum on the tank and all that air not being regulated by the maf cause the truck to act like a vacuum leak is occuring. I replaced the gas cap when I did the solenoid under the truck.
Last March I replaced solenoid/gas cap under the truck. I replaced the hoses that go from the canister to the solenoid under the truck as well and those clamps are tight and not leaking. June I replaced the valve at the engine. Mid July I got the small evap leak code again and maybe once a month i got the code. Mid November is when the truck started acting up after removing the gas cap.
Sorry for the long post. Anyone have an idea? Am I on the right track or perhaps maybe one of the valves i replaced is malfunctioning again.
I have an Autel (which is like a tech2) i can borrow whenever so if theres a procedure known to run so I can test the evap system, let me know. I used the autel to tell me what airbag sensor was bad, among many more fun things.
Thanks in advance for any advice.
Old Jan 20, 2015 | 10:40 PM
mdwatts11's Avatar
Does it do it only when you get gas or can you just remove the cap in your driveway and it still does it?
Old Jan 21, 2015 | 08:30 AM
iamkeniff's Avatar
Try turning off all your evap codes and see if it continues
Old Jan 21, 2015 | 02:09 PM
Anytime i remove the cap it does it.
Ive cleared codes everytime they have come up. Code sets dont appear to be linked to the issue on a time base. As in, the code set is random. Anytime i open the gas cap is when i have the hesitation
chopperloco
Jul 10, 2016 10:45 PM
Ketis
Jul 23, 2015 12:37 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
Nimoryan
Jul 5, 2015 03:50 PM
