Window Switch Part Check
At some point, GM made a regular cab truck with the DL3 option, power folding mirrors. I am trying to find out what year this may have been and any other details one may have. I know they did because I found a few windows switches that could have only came in that configuration. All extended and crew cabs had power rear windows for a total of (4) window switches. This switch (photo attached) only has provisions for (2) windows but with power folding mirrors. This must have been a regular cab with power folding mirrors but I have no idea what year(s) they did this.
EDIT****
Or if anyone can post a link to a truck like this that would be awesome too!
EDIT****
Sorry, forgot to add them...
The part numbers for this switch are 20877338 and 20835557
The part numbers for the bezel are 20922505 and 20877673
A VIN to a truck that came stock with this option would be nice.
My end goal is to purchase the door wire harnesses that go with these switches. I just can not for the life of me find a truck VIN to go along with this option.
Thanks!
Thanks!
Do you have a part number for the door harnesses that work with this switch? That's what I am really after. That or a VIN to a truck that had these switches as stock.
It should be a reg/standard cab harness with the up-level/data bus connectors. I seem to keep coming up with numbers for harnesses that are not data-bus.
Thanks for the help!
This is what I show
22912629 L HARNESS, FRT S/D DR WRG - LH CK2 (03-43-53) DRVR & PASS FRT SPLIT SEAT (AZ3),FRT HIGH BACK RECL BKT ST (A95),HEATED,POWER FOLDING,LIGHT SENSITIVE RH & LH O/S MIRROR (DL3),ENHANCED SPEAKER SYSTEM (UQ3),SILVERADO/SIERRA CLASSIC/SLE PKG (YE9), (EXC LH & RH ROOF INFLATABLE RESTRAINT (ASF) 2011-2013 01 104.82 12H 4463A
Would this power fold in Mirror feature work on an LS model truck ? Mines a 2011 Silverado LS Regular Cab. Has PW Windows, Locks and Mirrors. I added the PW fold in mirrors with turn signals. Turn signal and adjust works but would like to add the fold in option as well. If anyone can point me to the right direction I’d appreciate it thanks!
