Need some input
Old Mar 6, 2010 | 09:58 AM
WHITE5.3L's Avatar
Default Need some input
I just got my asp underdrive pulley installed on my 5.3l. The install went great i got the longer ARP bolt on there and everything. The truck runs great, but what is happening is that i hear like a little whine noise at idle and when i take off from a dig. It almost sounds like alternator whine, i noticed that my voltage shot up when i installed as well. Any suggestions re tune? idk..
Old Mar 6, 2010 | 10:41 AM
iamkeniff's Avatar
wait u have the UD crank pulley only right? did you do the over drive ALT pulley?
were the belts in all the grooves? it sounds like your off 1 groove or the tensioners are going bad
Old Mar 6, 2010 | 12:10 PM
WHITE5.3L's Avatar
yup i have the UD crank pulley, nope i dont have the over drive ALT but i have the underdrive ALT that i have not installed yet.
Old Mar 6, 2010 | 05:53 PM
iamkeniff's Avatar
so wait u bought 2 main drive belts?
i sounds like a tensioner or idler pulley
Old Mar 7, 2010 | 12:14 AM
WHITE5.3L's Avatar
yes sir i have the correct belts on it as well. I got no clue why this is going on, it bugging me. Im going to mess with it tomorrow.
Old Mar 7, 2010 | 12:48 AM
Dewey's Avatar
if you installed an underdrive pulley, i have absolutely no idea why your voltmeter is spiking higher than normal. i'd suggest that you hook a multimeter up to the output of the alternator and test what you're getting. does the whine come from inside the cab or under the hood
Old Mar 7, 2010 | 11:41 AM
WHITE5.3L's Avatar
The belt was the problem guys. All i did was buy a new one and it fixed the whine. The original belt that i had got had a different style grove and that is what was making the noise.
SloSVO
Nov 22, 2020 07:34 PM
trevorh1
Sep 27, 2015 08:47 PM
Cha_Feel_
Sep 23, 2015 09:06 PM
Parriott31
Sep 22, 2015 08:44 PM
