need pic 2010 MAP sensor plug
Old Jul 15, 2013 | 03:06 PM
BIGDADDY1969's Avatar
Cool need pic 2010 MAP sensor plug
I had this in other GM section and going to ask in here now .. i just copied and paste from there
heres a pic of my 08 MAP sensor pigtail ... im needing a pic of a 2010 MAP sensor wires to figure something out .. ive swapped to a 2010 ecm to run my 2010 6L80E swap since my 08 ecm wouldnt .. i have a thread already in ref to this not going there again explaining lol ....the 2010 ecm im running wont read my MAP .. i bought a new 08 MAP thinking that was the problem but its not .. ive since checked for continuity and its fine .. thinking on repinning it to a 2010 MAP pinout so thats why im looking for a pic of someones 2010 MAP sensor to verify .. if that doesnt work im guessing i need a 2010 MAP senor instead ... first thing though i need a pic .... PLEEEEASE!!!!!!!!
__________________.
Old Jul 15, 2013 | 03:16 PM
AUTOT3K's Avatar
i've got a 2010
I'll snap a picture tonight,
where is the MAP on this intake? I dont remember when I was unplugging everything to remove the intake
Old Jul 15, 2013 | 03:39 PM
Mine is on top intake just behind(past) the throttle body .. Mine is 08 tho im not sure if it changed
Old Jul 15, 2013 | 03:46 PM
AUTOT3K's Avatar
sounds good,
and you just want a pic similar to the one you posted?
I'll have that to you in about 3-4 hours
Old Jul 15, 2013 | 08:17 PM
AUTOT3K's Avatar
Top side
Old Jul 15, 2013 | 09:00 PM
AUTOT3K's Avatar
your goes Left-Right
Orange / Green / Grey
mine goes Left-Right
Grey / Orange / Green
Old Jul 15, 2013 | 10:07 PM
Cool
Yes thanks ... Thats what i needed ... Thanks .. Going to try n see if that helps switching wires ... Worse case it fries it but it isnt reading it anyway and if so im going to order '10 MAP to go with the ECM n it shud readthat ... Either way i needed the sequence of the '10 to try anyway .... Thanks
Will post results when i get a min hopefully when i get up tomorrow i can ... Straight nights here if not i wudbe out there right now
Old Jul 16, 2013 | 02:51 PM
Cool
... I repinned it but throws red power mode... Im going to order a 2010 map sensor n see if it starts reading that ... Thanks for the help i will use this to repn and splice i a 2010 pigtail as well cause the sensors are different from 08 n 10 ...
Old Jul 16, 2013 | 03:12 PM
AUTOT3K's Avatar
damn that sucks you gotta order the sensor
Old Jul 17, 2013 | 12:21 AM
Yea but i have another issue as well .. My 6l80e swap has been a pain lol i had to use newer 2010 ecm .. Theres a julian date change in mid 2010 production and had i gotten older 2010 trans i wud still be using my 08 ECM .. i wudnt have these little sensor issues with the MAP .. BUT i also have O2 sensors not reading on either of my ecms .. ive swapped back to my 08 ecm just to check and it wont read drivers o2either with my new harness SOOO im to the believe that i have issues with new wire harness cause nothing is reading the O2bank ..and ive swapped o2s from one side to the other and same issue .. Reading passenger no read drivers .. But it has power to it !!.. I havent had chance to check continuity on the o2 wires going to ECM yet but thats next ... then if that fails i ordering another wire harness .. Small things are the biggest pain ...
