Mpg's gone to hell
Ive noticed that the mileage on my 07 yukon went really bad in a matter of a week...nothing has change only some led's installed and i drove it with the towing on for about 100 miles and i wasnt towing anything..oh yeah and i got into a small fender bender on saturday...but i pumped gas and it was reading 140 miles and i drove maybe 2 miles and it went down to 110 miles..is it time to replace the k&n filter?
So did the mileage actually get worse or did your "distance till empty" just jump around?
Sounds like his Distance to Empty changed...
How about running a whole tank thru it and see what it comes out to be. |
Tank of bad fuel. We are getting to that time of year where the transition from winter blend to summer blend fuel is starting to come out and it always causes tons of headaches this time of year and in the fall from people bitchin about poor gas mileage. The full transition is usually done by april to may depending on what part of the country you are in Or you just flat got a bad tank of gas it happens.
Driving two miles is not enough engine run time for the computer to know anything, especially just after a fill-up. Give it a whole tank, or maybe a couple or three tanks, before you get worried.
I had to pump 87 last sunday and i noticed the problem after...i always pump 91 but they were out...i just dropped it off at the body shop to get the damage fixed from that fender bender i got into...when i get my truck back in a month ill fill it up and see what happens
I also noticed that whenever i put down my power windows or i turn the wheel all the way till it hits the idle drops from 700rpm to around 500rpm and it wont go back up till the electrical strain is gone.
Originally Posted by Elrey7698
(Post 5081753)
the idle drop when turning full lock is normal cause of the strain on the serpentine system |
Originally Posted by AUTOT3K
(Post 5089616)
how bad was this small fender bender?
(Post 5090012)
Her insurance replaced the whole front end. me being a dick! Took my truck to the most expensive shop in town and got all dealer parts. They even replaced both my rotors and pads. Replaced all the suspension components on the driver side. DRIVE LIKE A DUMMY AND IT WILL COST A LOT!
| All times are GMT -5. The time now is 01:25 AM. |
