Jamescb77 semi exciting NNBS turbo build
#61
Learning a little more and little. More and we are getting closer and closer to letting her rip.
Got the front end all the way back together and gave her a bath.
Can't wait to let it eat.
#62
Been working on nailing down this tune. Everyday we have been making revisions and getting it closer and closer.
Realized tonight I have an oil leak from somewhere. Trans cross member has drips all over it and there seems to be a tube hanging down right there? Anyone know what that is? Hoping its not from the back of the valley cover cause I really don't want to tear everythinf back down.
#64
#67
Well guys we still having got he tuning issue figured out. Ut I also have a pretty bad oil leak coming from somewhere. There was zero leaks before so its def something from installing the turbo. I check the oil drain and front cover and all those are good. I believe its either the valley cover or the oil dipstick. I guess I'll start tearing it back down until I find it and get it fixed. So close yet so far away.
#69
#70
So I think I got the oil leak fixed. I was tired of keeping an eye on it and having to check it all the tine so I tire it back down. It appeared to be leaking out of the back of the valley cover. Also made sure the dip stick was fully seated. Should be back together this weekend.
In addition we are having some problems with the tune where the commanded afr under boost wants to jump around and even spike back up sometimes. Trying to work through that and if it doesn't fix we will swap to speed density and see if it still does it.
