I think I'm over this 4.8
damn thats a sweet thread. all done looks like with their own skills as well as budget pieces. makes me want to dive into learning more about turbos for my truck on the stock motor with a ls6 cam and beefed up trans
The trans will be your weak link for certain but if your somewhat handy with a welder you can fab up your own kit emissions friendly on the low buck thats for sure. Those PM turbos are cheap and good. Intercoolers can be had for peanuts on ebay. Get some pipe and elbows and couplers and stuff it in.
The one part of the build ( well maybe two ) that you really should buy the best you can buy if you do a rear mount or midmount whatever you want to call that set up there the oil recovery pump for the turbo is key. Buy the best there.
Otherwise its a fuel system upgrade along with some injectors and a tune and your good to go.
If you shoot for the 400 whp range you'll still hit 12's and probably keep your trans held together for a while with a few small mods. Corvette servo etc. Best of all for a 400 whp goal you just run your stock cam and cats etc so your emission friendly and very civilized driving manners as well.
Its enough to womp 6.2's with ease
I rather go for that 6.2 engine swap with a 6 speed tranny.. My budget maybe I can thrownabout 3k-4k.. I still owe the truck have mortgage payments :-(.. plus that dude it's in YouTube... That turbo set up has a lot of lag... And he is hitting mid 12's..
Thats just one of hundreds of boosted 4.8 and 5.3 builds over there. Heck maybe thousands and the lag? its all in how you select the trims and whatnot. Anyways to each his own but your not going to come close to a 6.2/6spd swap for that kind of coin. Double it and you'll be in the ball park
Believe me... Im swapping a 6.2 right now its pricey to do engine swaps properly. You'll need a new PCM and tranny module and wiring harness plus a tune and a fuel system anyways. Not saying it wont be great but its not as easy or cheap as you seem to think. Mind you if you stick with the 4spd then its not really that big of a deal you can re-use your harness and PCM but still need a tune
If lag free is what you want get a maggie
FWIW He ran mid 11's then ran out of fuel control due to the e38 PCM and HpTuners issues
True. It is pricey but I have seen the the whole engine tranny and hardness for like 3 k ... I can do the labor. I know someone selling a procharger used for 3500 he has a receipt and everything he had it on for two weeks... Or just find a ly6 and straight swap it and sell the 4.8 and then cam the 6.0... I wouldn't mind camping and turboing the 4.8. Thanks guys for the ideas... Keep giving me ideas bros.
you dont need a PCM to run a 6.2 in your truck, nor a harness IF you already have a 4.8/5.3
you need a harness ONLY to run a 6L80e in your truck.
you REUSE your PCM, and you do not have to upgrade ANYTHING for the fuel system.
i ran 12.73 @ 104.54 backed up by a 12.74 @ 104.95 with a transmission going out.
my 6.2/6L80e *cam, milled heads, lifters, oil pump, head gaskets, ARP everything, dual springs, pushrods* swap was less than a 72mm front mount turbo set up, gauges, fuel system, injectors, and you can find a LS2 cam *same as a Zo6 cam just a single bolt and more lift if i remember correctly*
All the ones I have seen Around here want 4k-5k, some even close to 6k. I live a few miles from L.A. in orange county.
Well there was a point when I was Gona sell my truck. But then I decided to keep it. So I never jump on deal for the engine. I was gona get a gto or a corvette ls2. I guess ima have to drive to niff so we can make this engine swap happen lol.
