" Hood Open " - Switch gone bad
Posting up as info as I'm sure others will run into this
Changed oil tonight and once completed the dash alert "Hood Open" appeared. Upon diagnosis the switch itself was in pieces. Probably had something to do with age, the temp around zero, and closing the hood firmly. I'll need to pick up a new one switch/latch assembly. I could not find a switch only offering only a switch with the latch system. I also determined that the remote start does not work when this switch thinks it is open (part of the anti theft I imagine). 2007 silverado |
Interesting, I don't have a hood open switch. I am glad.
(Post 5186774)
I had never heard of one till tonight :-( so much for warming up the truck from the warmth of the house in the AM lol |
does your have 3 wires?
Pink/Black Purple Black? |
1 Attachment(s)
if yes...short the purple one to the black one (threw the connector with something) and that should stop the hood open chime until you can replace it, I'd use a cotter pin and tape it in
the purple is your hood closed signal pink/black is hood open signal black is the ground and depending on what position the switch is in...grounds a different wire Attachment 106226 |
Originally Posted by AUTOT3K
(Post 5187533)
Pink/Black Purple Black? Part is enroute --- in Warrendale PA at the moment so I guess it'll be here Monday |
Thanks - I will take a closer look
(Post 5187534)
the purple is your hood closed signal pink/black is hood open signal black is the ground and depending on what position the switch is in...grounds a different wire http://i1265.photobucket.com/albums/...psc692a5a0.gif |
Switched arrived this afternoon
wiring on my setup is Black Yellow Purple Back in business |
hmm strange, I checked a couple of years and they were all the same wiring as before
yours is a 07 NNBS right? any special trim level? |
for anyone wanting to save a couple of bucks ,when the switch fails you can take it apart by grinding off the 3 little round bumps on the side and prying it apart. the problem is the printed circuit board has failed and you can just solder a wire across to jump the failed board . when done just glue the switch back together . you can fix it faster then the time it would take to order a new on . 10 min fix.
