Help Ticking sound
no just upgrade your current rockers with the comp cams trunion kit, its a fraction of the cost of new rockers and it takes max 45 minutes to install the push rods wait and see, if theres no damage to the ends then dont waste that money
i'd hope its not a lifter haha the head has to come off for that!
Mine has 6k on it and it was the second time i got into boost it let go. Im hoping AUTO is right about the rockers being junk and breaking a bearing that would be a nice easy cheap fix. I'll let you know what i find.
Well i have bad news i got in touch with a local Ls Guru and he met me down at my truck we pulled the valve covers off and valve train is fine. He seems to think i have some very bad luck and a piston skirt cracked or rod bolt. So yea i'm screwed for a little while till i can enough money together for a rebuild.
Well I'm sorry to hear that man!
Listening to your video it really doesn't resemble a rod knock or piston noise but maybe the camera isn't picking up on it fully
When you do tear into the engine I'd start at the top cause if you pull the heads and it is a failed lifter you can stop there and just repair that!
