Help me please!
Help me please!
2007 silverado CC LTZ NNBS
5.3 AFM All aluminum
Codes read:
cylinder 6 misfire and the TCC light comes on.
They both go off together. It happens if it idles for any period of time. What are the things i should explore?
Thanks in advance.
Codes read:
Thanks in advance.
no it wouldnt be a clogged cat otherwise you'd have issues on that whole bank and itd be under load conditions
check the spark plugs for the misfire, at 60K you'd probly be due, I know book says 100 but thats not real life haha
the TCC issue, no codes? throttle still works properly? no shifting issues?
The svc traction control lamp is coming on because the pcm disables it under certain condition when various trouble codes are set. A misfire DTC is one of those codes.
Basic trouble shooting does it have spark and does it have fuel use a noid light to check for injector pulses. If it has those then you gotta go deeper but that's where you start at.
