Help me build a fuel system!
Old Jan 17, 2012 | 09:10 AM
Area47's Avatar
i have run surge tank setups before and work great. mainly for road racing setups vs ***** out straight line runs. leave the intank pump alone. run a single bosch 044 for cruising around town. add a hobbs switch and a seconday bosch 044 that kicks on at what ever psi you want. i have seen a single 044 sustain 940 whp in an awd car. twins will sustain it.
just because this isn't the forced induction section, doesn't mean some of us haven't been down this road before.
Old Jan 17, 2012 | 09:31 AM
smokeshow's Avatar
Mod with training wheels
My fuel setup is pretty simple...dual walbro 255s with one on a dedicated pump controller, all through an aeromotive fpr. Took my single stock pump over 600rwhp (with some methanol help) so I have no doubt a pair of walbros will net over 1000. If not the 3rd walbro in the nitrous fuel tank will pick up the slack
Old Jan 17, 2012 | 10:31 AM
Gray Ghost Silverado's Avatar
Good good! This is all exactly what I need!
Old Jan 18, 2012 | 12:00 AM
v502's Avatar
We are in same spot and this is what I am doing on my truck.
4 gallon surge tank in stock battery location with 2x044 pumps, one will be constant and other will be triggerd by boost. I calculated that it take 8 mins for full 4 gallon tank to run out fuel and thats without the stock pump. I am aiming for the same power range and at the level of power it blow up before you run out fuel
This what parts am using for custom surge tank that will help you
Integrated Engineering Billet Surge Tank Front Plate Dual 044
IE Fuel Pump Manifold Kit for Dual Surge Tank
and this is diagram of the setup in engine bay. Good luck and keep us posted with pic's
Old Jan 18, 2012 | 02:25 PM
Mmmm, well, I'm going to try something with a Magnafuel pump, kind of like Jake's setup, run off a 4psi Hobbs Switch. Will post pics soon. Keep me updated on your setup.
USMCvet0311
Aug 14, 2015 10:28 PM
MS3Z
Jul 30, 2015 06:17 PM
4B11T
Jul 13, 2015 03:48 PM
Deceptarado
Jul 8, 2015 05:24 PM
