Headers Installed pics inside
Here's a link to the coating I used there's different colors, but this is the one I went with.
http://store.summitracing.com/partde...5&autoview=sku
that is correct, the headers go in no problem. You will have to modify either the y-pipe or the stock exhaust. I chose to modify the stock exhaust so I wouldn't chop up the y-pipe. You just have to cut back the stock pipe about 7 inches that's it, no biggy
great idea on the coating yourself. If i were to coat a set of pacesetter LT's, would it make them last alot longer? i remember being told the non coated LT's are good for 4-5 years but can i get 7 or so if i coat them myself?
I'm going to fail you on this one buddy. I've never used this coating before, but it went on pretty good and stayed there pretty good after heating it up a bunch of times after the install. I guess only time will tell if it's going to hold. Also think about the heat there is not near as much heat at the y-pipe as there is at the headers. The coating says it's good for 1700 deg
