Getting a 2wd rcsb to hook...
Old Jun 18, 2015 | 07:58 PM
121's Avatar
121
Default Getting a 2wd rcsb to hook...
Got a 2wd rcsb 370 s475 th400 caltracs bogarts with 29.5x10.5x15 for rubber in the rear no sway bars 4/6 drop with flip kit. What do I need to do for getting this pig to hook I've tried a few things? Thought about fabbing up straight behind the axle shock mounts to try. Any other suggestions? Much appreciated
Ryan
Old Jun 18, 2015 | 08:18 PM
George C....'s Avatar
Formerly ScreamingL
describe how you have the chassis setup
describe the shocks youre running front and rear
describe how you have the caltracs adjusted
describe where your trucks weight is front/back ratio
Old Jun 18, 2015 | 08:41 PM
121's Avatar
121
George,
Everything is new on the truck so I have alot to do towards setting up the chassis I know it's trial and error kinda deal but I want to be in the right direction if possible. Shocks and struts are mcgaughys . Caltracs are adjusted according to caltracs tech. Not cranked down alot but the roller definitely does not spin on top of the leaf. The weight is a guess right now I need to scale it soon as I can find some scales.
Old Jun 18, 2015 | 10:28 PM
Formerly ScreamingL
You should have adjustable shocks for Caltracs and not lowering shocks
Did you adjust Caltracs with weight of driver in place?
Old Jun 18, 2015 | 11:40 PM
121's Avatar
121
Ok I'll fix that
No I didn't I can do that also. I'm about 2 turns tight on the bars
Old Jun 20, 2015 | 06:49 PM
dick_landy's Avatar
Mine is stock height with rear blocks removed, front sway bar removed, caltracs set as per the instructions, 315/60r15 ET Streets at 20 psi on 15x10 cragar soft 8's, stock front wheels and tires. When it had stock shocks all around it yanked the wheels off the ground, I have rancho rs9000's in the rear now but haven't really driven it since they were put in.
Old Jun 21, 2015 | 08:36 AM
121's Avatar
121
That's awesome. I'm gonna try viking or qa1 haven't decided yet
pewter00
Dec 13, 2015 10:38 PM
mitchellmade
Sep 27, 2015 08:25 PM
MadDMax66
Sep 5, 2015 01:27 AM
God Made Chevy
Sep 4, 2015 12:29 AM
