Flexfuel pump swap into non Flexfuel NNBS ???
Old Feb 8, 2015 | 06:14 PM
  #61
wanablaze's Avatar
So all that is needed is a flex fuel pump and fuel pump driver module? Was it plug and play or was programming required? No sensors needed to be changed for the new flex fuel parts?
Old Feb 8, 2015 | 06:39 PM
  #62
vettelovralexand's Avatar
Just bought the two parts, plugged em in and they worked. They just had to be matching parts. And from what i understand there are several part numbers for the fpcm which just have different programming depending on flex vs non flex fuel. So, if you buy a new one, you have to get it flashed or you may be able to get your current one flashed. I just found a same year flex fuel truck part on ebay to avoid that hassle at the dealer.
Old May 22, 2015 | 08:28 AM
  #63
Mr. Chainsaw's Avatar
flex fuel pump gm # 19257095 (mu2142), only thing I had to swap over was the pressure sensor in the fuel pump and i modified the locating tab. used fuel pump module 20791901. plug and play. hope this helps someone.
Old Jun 17, 2015 | 04:00 PM
  #64
Turbo09's Avatar
^Where is this pressure sensor in the fuel pump?
Old Jun 17, 2015 | 05:56 PM
  #65
red99red's Avatar
I reused by old pressure sensor, its for the tank pressure not line pressure. It is located on the hat assembly. It is plugged into a rubber grommet just pull it out and put the one from the old hat in.
Old Jun 21, 2015 | 03:41 PM
  #66
05GMC4.8's Avatar
ill add what ive done in here...
..... i got a flex pump from a 2008 silverado, dropped it in as it came and i got a fpcm from a 2008 flex fuel suburban. put it all back in and fired it up once the fuel lines filled with fuel and got the air out it idled smooth as stock. i turned the truck off and on a few times and even used the remote start. pressured up to 60psi and once warmed up pressure dropped to 43.5 psi or so just like before the swap. i have yet to drive it tho cuz im still waiting on my 4l80e to come in
Old Sep 19, 2015 | 01:50 PM
  #67
chopperloco's Avatar
Has anyone tried just the flex fuel pump swap without changing the module?
Dom
Old Oct 12, 2015 | 09:51 PM
  #68
setxathlete14's Avatar
Dom
Just did this yesterday its a pain but it works too
Old Oct 13, 2015 | 03:55 AM
  #69
Turbo09's Avatar
How did it go? No codes?
Old Oct 13, 2015 | 06:39 AM
  #70
Dom
Mine threw a light and the fuel pressure was backwards when I did it this way. When you loaded the truck the pressure got commanded low and then out of load went high. Truck still drove fine, but the logs showed that it wasn't right and the dash light never went away until I swapped for a flex fuel fpcm. (see post 59)
