evaporator core
Has anyone every changed on on the sierra? I have a leak that isn't showing anywhere with uv leak detector. Wondering what i'm in for repair wise. Didn't find much online about changing one
I haven't done one on a newer model truck but I can tell you it's not going to be fun.
Ideally you will need to drop the steering column, then start unbolting the dash so you can pull it forward and away from the fire wall. Then kinda pull the passenger side over more at a angle to get at the entire heater box. Remove the whole heater box assembly and replace the core. You'll have to disconnect the heater core lines as well. |
Dam. That's not what I wanted to hear at all. Probably still better than taking it to the dealer and getting charged an arm and a leg.
I looked into it and it's a 7.4 hour job with a truck that has bucket seats.
I would look into buying an alldata subscription for just that truck or find someone that can give you a step by step print out from a dealership, all data or mitchel on demand. There are a lot of steps to take when doing this. |
Originally Posted by FFDP
(Post 5416063)
She back to blowing cold! Turned out to be the condenser. Trans cooler rubbed a hole in the condenser. I had the cooler right up against it since my intercooler was in the front. Now that the intercooler I moved the cooler back to the front
thats good! i traded my single cab in when the evap went out... i was quoted 3 grand to replace it..
Originally Posted by colekill
(Post 5416191)
Just a fyi for those of you who may need to do a evap or heater core in the future if you have the SLT, LTZ or the LUX dash you may as well plan and budget on the upper dash filler panel and the top dash panel. Unless you have religiously kept it covered and or in a garage it's whole life the dash will crumble and crack as soon as you disturb it. Plan on replacing the heater core at the same time as well it's very cheap insurance if you don't want to do the job twice.
If you have the standard sierra or silverado dash the upper dash filler panel underneath the windshield clips break every time as well, the dash is only fractionally more durable. |
