Drop struts or spindles?
Old Aug 20, 2012 | 12:56 PM
Jake Wade's Avatar
Default Drop struts or spindles?
I am wanting to drop my 2008 Silverado 2WD 2" on the front.
Which is the best way to go: Struts or Spindles?
Would I have to have a realignment with either?
Old Aug 20, 2012 | 01:15 PM
iamkeniff's Avatar
Spindles require you to cut your balljoints down to fit a 17" wheel
Struts are a nice way to drop it.
Coils is another way but over time could lose its spring rate and sag
Coil relocators is cheaper than all 3 options above and drop it 2" along with you not trimming any balljoints nor alignment issues.
Yes anything you do to the front end as far as height changes requires an alignment
Old Aug 20, 2012 | 04:54 PM
GMCSIERRA5.3's Avatar
2 inch springs is what your looking for less money and less work to install them
Old Aug 20, 2012 | 05:04 PM
Chevy_King1500's Avatar
I installed 2" drop spindles on my dads 2010 crew, and it rides great and handles even better. Had to cut ball joint studs even with 18" wheels.
Old Aug 20, 2012 | 06:52 PM
iamkeniff's Avatar
springs are poo over time, id rather do the coil relocator kit for 150.00
Old Aug 20, 2012 | 06:57 PM
07ccz71's Avatar
I had drop springs and couldn't stand the ride with 22's I removed them after a month!! Spindles struts or coil relocators are the only way I would suggest to retain ride quality.
Old Aug 20, 2012 | 09:07 PM
Jake Wade's Avatar
Thanks, I had not heard of coil relocaters. I will look into it.
Old Aug 21, 2012 | 05:49 AM
iamkeniff's Avatar
let us know if you cant find them, ill pm you the link to them.
Old Aug 22, 2012 | 03:18 PM
beastmode's Avatar
Import Moderator
Being a longer wheel base truck I would avoid the spindles if you are only looking to go 2" lower, they change your turning radius. I had Belltech Street Performance adjustable struts on my crew cab and loved them. I had a Z71 with the Rancho struts (OEM) and absolutely hated how bouncy they were.. the Belltech SPs gave it a "comfortably firm" ride. Plus they were $180 shipped and didn't even require breaking any ball joints loose or removing the hub from the spindle.
Old Aug 22, 2012 | 03:44 PM
romemachine's Avatar
^dude's owned more trucks than imaginable. all different set-ups too. he definitely knows his talk. just my .02, i'd take his suggestions strongly.
