Drivers side CV axle ?????
Old May 26, 2016 | 12:25 PM
Jonblarc7's Avatar
Default Drivers side CV axle ?????
I pull into my Mom's neighborhood at lunch and it felt like a 4x4 trying to make a tight turn. I know I'm AWD but it has never felt like this before.
So I crawled under it and see the boot closest to the wheel on the drivers side is throwing grease everywhere.
How long do I have LOL.
I mean should I not pull my boat 15 mins to the lake tonight.
and should I fix it before I pull it 45 mins to the lake for the weekend.
Old May 26, 2016 | 01:05 PM
FFDP's Avatar
It's already bad, so it's not going to get better that's for sure.
With them not being super hard to replace, I'd do it as soon as you can to stop it from making a mess and getting even worse.
Old May 26, 2016 | 01:19 PM
Wolftrk99's Avatar
It could be the cv shaft binding, but ive seen the carrier bearings in the front diff do what youre describing.... The get worn and start binding on low speed turns....
Old May 26, 2016 | 01:57 PM
Jonblarc7's Avatar
Since it literally started leaking today.
(I know this because I have a striped screw from when I did the Norcal Mod. That I have to pop back in it's hole so my tires don't rub when I back up.)
Do you think I'll be alright until the first of next week. I really don't have time to change it before the weekend. And I defiantly don't have time to change it before we go ride tonight.
Old May 26, 2016 | 04:36 PM
Wolftrk99's Avatar
Hard to tell.... Seen them last years with bad boots and also had one come apart on me on the interstate, that i didnt even know was leaking.... That was fun in a 3500 dually, at 70ish mph
Old May 26, 2016 | 04:40 PM
Wolftrk99's Avatar
I gotta ask what is the norcal mod???
Old May 26, 2016 | 05:00 PM
rocknZ71's Avatar
If you're referring to the norcal fender mod it's where you cut metal out in the rear of the front wheel well then bend the left over and zip tie the liner back in for increased room for bigger tires/wider wheels. Don't know all the details but there's plenty of info on gmfullsize.com.
Old May 26, 2016 | 09:06 PM
Jonblarc7's Avatar
You are correct when I did it to my truck I used self tapping screws to pin the the fender liner back and had the drill on the wrong setting and stripped it.
Made it to the lake tonight no problems so I'll wait until next week to put a new one in. It's got 140k on it so it's had a good life.
Old May 26, 2016 | 09:14 PM
Wolftrk99's Avatar
Hell maybe i should look into that mod, i have a bit of contact of tight turns....
Old May 27, 2016 | 07:50 AM
Jonblarc7's Avatar
This is how it is done.
2007.5-2014 NBS HD *LARGE* Fender mod (Step by step pics) - Chevy and GMC Duramax Diesel Forum
01ssreda4
46
Jun 30, 2020 03:59 PM
Mark Johnson
May 27, 2016 09:11 AM
someotherguy
May 26, 2016 11:00 AM
