DoD port delete using pushrod ,.. Pics ..
Old Jan 12, 2014 | 03:07 PM
chevellepowered's Avatar
Default DoD port delete using pushrod ,.. Pics ..
Im cheap and dont wanna buy a ls3 cover or drill and tap the DoD ports , so i took a push rod, cut into 8 sections , tac welded the end , prob could use jb weld if dont have a welder .. and drove them in the dod ports.. very tight fit , didnt have to hit them to hard tho .. there deffinelty snugged in and arnt moving ,, thought i share ..
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Jan 12, 2014 | 09:20 PM
AUTOT3K's Avatar
well that's one way to do it!
Old Jan 12, 2014 | 09:25 PM
Atomic's Avatar
I have a gauge for that
That has hack written all over it
...coming from the guy that has 10 miles of zip-ties on his truck
Tootall's Avatar
wow . . .you are cheap. The cover is under $40 bucks
Old Jan 12, 2014 | 09:34 PM
AUTOT3K's Avatar
my concern would be, being an interference fit and hammering them in....where did the metal shavings end up going (down into the oil passages)
Old Jan 13, 2014 | 04:36 PM
iamkeniff's Avatar
for all that you should have pulled the cam and the pan then used a tap set to put brass plugs in
Old Jan 13, 2014 | 06:15 PM
03sierraslt's Avatar
MattOKC
Aug 18, 2015 11:30 AM
chacho44
Aug 17, 2015 03:36 AM
Matt331
Jul 26, 2015 09:40 PM
EscaTruck
Jul 20, 2015 11:42 AM
