converter swap truck not moving
Old Oct 25, 2011 | 12:18 AM
  #41
gonzo 6.2's Avatar
Originally Posted by smokin sierra
Also truck ran fine once factory converter re installed
sounds like you did a lot of work to find out you did nothing wrong.
I hate when someone sells **** parts and as good condition.
Old Oct 25, 2011 | 06:09 AM
  #42
smokin sierra's Avatar
What would cause this converter to be 1/4'' off from factory converter? Are the new 60e different from nbs 60e?
Old Oct 25, 2011 | 07:22 AM
  #43
Rhino79's Avatar
9 Second Club
No they arent. If it was clicked in all the way and it was still that far out, something wrong with the converter.
Old Oct 26, 2011 | 03:31 PM
  #44
AKlowriderZ71's Avatar
11 Second Hall Moniter
They are usually smaller & lighter than an original converter, for performance. They also need to be able to bolt up to a wide range of styles and/or thickness of flexplates, both stock style, or aftermarket SFI, oreven billet flexplates. Most of the time, shims will be needed with an aftermarket performance converter, if you are using a stock flexplate.
Just as an example, here's a couple pics of a stock 4L60E converter next to a Yank PT3200. You can see that it is a smaller diameter, and the body of the converter is also shorter(front to back).
Old Oct 26, 2011 | 07:15 PM
  #45
Default ...
Thank you for the picture explanation! I see what yall are saying. The seller bought converter back and installed in his truck WITH it shimmed and he had same symptoms. Has to be converter.
Old Oct 26, 2011 | 10:42 PM
  #46
Smile
Too bad you had to go through all that, and the 'verter was bad. At least the seller bought it back.
Old Oct 26, 2011 | 11:35 PM
  #47
2doorfury's Avatar
will yank rebuild there
converters??
Old Oct 26, 2011 | 11:36 PM
  #48
Yes he does. Give Dave a call for his prices.
lxcoupe
Aug 15, 2015 06:13 PM
black6spdz
Jul 16, 2015 01:32 AM
Deceptarado
Jul 8, 2015 05:24 PM
ALynch
Jul 6, 2015 09:49 AM
Nimoryan
Jul 5, 2015 03:50 PM
