Code P0449
Old Jul 15, 2012 | 12:04 PM
camaross82's Avatar
Default Code P0449
Ok, I have a 2010 gmc sierra with a 5.3, and my cel came on this week. I went to advance auto and used their scanner and it came back P0449 evap vent solenoid valve. They don't have a part for it. And I googled it and can't find anything past an 06 that has the issue. The scan tool they have is only updated to 08 models, Could this be an issue with a different code for newer models?
Old Jul 16, 2012 | 04:26 AM
camaross82's Avatar
Nobody?
Old Jul 16, 2012 | 07:04 AM
Allgonoshow's Avatar
Originally Posted by camaross82
Nobody?
The code is probably valid.
could be a loose gas cap, if not, likely the vent valve solenoid at the tank.
do you want to fix it your self or are you going to a shop.?
Old Jul 16, 2012 | 11:53 AM
camaross82's Avatar
I removed and installed the gas cap a few times to check that. No luck.
Ill prob fix it myself since I think the emissions warrenty is expired since I have 47k on it. I guess Ill have to go to the stealership for the part though since my local part store doesnt have it. Any idea how much they cost?
Old Jul 16, 2012 | 11:59 AM
gavin2005's Avatar
allgonoshow is right on the vent valve solenoid.i replace alot of them for that code.yes it is a dealer only part.some are cheaper than others but i think the truck ones are around 100 bucks.
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
Pimpinpete
Sep 8, 2015 07:39 PM
