Chasing a water leak for months.
Old Feb 14, 2025 | 11:56 AM
Project46's Avatar
Default Chasing a water leak for months.
2008 Sierra Denali and drivers floorboard fills up with water with every rain. Checked all sunroof drains and everything working as it should. I poured water I to the sunroof 1 gallon at a time to completely fill it up and keep it full to try and find the leak and al drains work perfectly. Headliner never gets wet but even a small rain and the floorboard will have standing water. I can’t find any sign of the windshield leaking but that’s the only other think I can think of . Any ideas where else I should check?? I’m about to pull my hair out with this thing.
Old Feb 14, 2025 | 12:09 PM
wretched73's Avatar
have you checked the 3rd brake light?
Old Feb 14, 2025 | 12:11 PM
Project46's Avatar
I sealed that first and moved on to the sunroof. The headliner never gets wet but the drivers side front will have standing water in it. I even thought it might be running down the side window and draining inside the truck but there isn’t any sign of it.
Old Feb 15, 2025 | 07:18 PM
shakenfake's Avatar
Shlumpt
5 Year Member
Pinch weld in the engine bay I think is a common spot.
Have you checked your windshield?
Check inside your door and make sure your wire boot is in correct.
Old Feb 15, 2025 | 08:13 PM
Project46's Avatar
I ran water down the lower half of the windshield and got water running on the inside near the kick panel. I pulled the cowl and found the sealant really cracked up and dry. I cleaned it with acetone and going to reseal it and check again. If this doesn’t fix it I’ll replace the windshield.
Old Feb 18, 2025 | 12:23 PM
bisqikss's Avatar
more than likely it is the cab vents on the back of the cab. sounds crazy, but with everything else you have tried. that is all that is left
Old Feb 18, 2025 | 03:24 PM
shakenfake's Avatar
Shlumpt
5 Year Member
If it isn’t wet in the backseat I highly doubt it
Ryan Hampshire
Mar 2, 2017 04:41 PM
1SlowHoe
Nov 3, 2010 04:45 PM
GMCtrk
Aug 14, 2008 11:55 AM
Breeze
Mar 8, 2005 02:28 PM
yeary03SS
Nov 29, 2003 02:55 AM
