Chasing a water leak for months.
2008 Sierra Denali and drivers floorboard fills up with water with every rain. Checked all sunroof drains and everything working as it should. I poured water I to the sunroof 1 gallon at a time to completely fill it up and keep it full to try and find the leak and al drains work perfectly. Headliner never gets wet but even a small rain and the floorboard will have standing water. I can’t find any sign of the windshield leaking but that’s the only other think I can think of . Any ideas where else I should check?? I’m about to pull my hair out with this thing.
I sealed that first and moved on to the sunroof. The headliner never gets wet but the drivers side front will have standing water in it. I even thought it might be running down the side window and draining inside the truck but there isn’t any sign of it.
I ran water down the lower half of the windshield and got water running on the inside near the kick panel. I pulled the cowl and found the sealant really cracked up and dry. I cleaned it with acetone and going to reseal it and check again. If this doesn’t fix it I’ll replace the windshield.
