Best of the cheap 1 7/8 long tubes?
I'm trying to decide between the different 'value' headers available. In 1 7/8 size, I'm aware of the following:
Texas Speed
Speed Engineering
PaceSetter
Each seems to have their pros and cons, and from what I've compiled:
Texas Speed
Pros:
stainless steel
one piece tube (not seam welded)
Cons
y pipe needs modification for 6 speed
Speed Engineering
Pros
Stainless steel
lowest price of all with y pipe
3.5" flange for y-pipe
Cons
seam welded
Lots of reports of fitment issues - o2 sensors hitting, contact with frame, lots of beating needed to fit
Pace Setter
Pro
Available coated
Cons
mild steel, not stainless
Y pipe is only 3"
When considering all of the cheaper long tubes, is there any kind of general consensus as to which is the best as far as longevity and fitment? I know and accept that there will need to be y-pipe modification/customization, especially as I plan to add a single 3.5" cat to reduce the smell. I had originally planned to get Speed Engineering, but the fitment issues I've read had me hold off. I figured Texas Speed would be good, but the issues with the Y-pipe gave me reservations, and I like Pacesetter, especially since they are coated, but it is just mild steel, and their Y-pipe is only a 3" exit I believe.
Thoughts or recommendations?
Texas Speed
Speed Engineering
PaceSetter
Texas Speed
Pros:
stainless steel
Cons
Speed Engineering
Pros
Stainless steel
Cons
seam welded
Pace Setter
Pro
Available coated
Cons
Y pipe is only 3"
Aren't the fitment of SE headers not recent? I thought they had worked that out. A buddy of mine didn't have issues on his '15. They are my current favorite.
langsbr (04-22-2019)
Thanks
langsbr (04-23-2019)
I havent put my SE headers on, had them on my last truck and they worked great.
What i realized on this new set for my NNBS, one of the header primaries was beat around a curve..
Never knew they did that or i wouldve opted elsewhere. Maybe its not crucial, but it just looks terrible and i know its there
I had ODX headers and Y pipe on my last 08 denali with the 6.2. They where 1-7/8" and I had no fitment problems. Ran them for at least 50K miles
I bought band clamps at Napa to use instead of using the ones they supplied. But when I swapped to a magnaflow 12909 I just had them weld the Y pipes together.
