available cams for 6.2L sierra
#61
REVIVED FROM THE DEAD
VVT leverageS new technology for best results but the LS9 (non VVT) cam results are amazing on a members 6.2L. Would a cam ground similar to the LS9 specs but designed around the VVT technology produce even better results? OR....could one of the new Comp VVT grinds outperform the LS9 Cam? The dyno results on the LS9 cam show peak gains of 43rwhp/18rwtq but at a point over 5k it continues to build power after the stock L92 cam tapers off and there is a difference of nearly 100rwhp.
Link to the LS9 cam thread below
https://www.performancetrucks.net/fo...s-dang-490303/
I'm doing the ls9 swap just like that OP! I can't wait!!! I'm doing headers and cam at same time!!
#63
I have compared this swap to installing an LS6 cam in an LS1. It produced very good peak numbers, but didn't have near the midrange power of a well spec'd custom grind. There were a lot of guys who were happy with their swap though, so that's all that matters.
#64
You will gain a significant amount of midrange torque with a small to moderately sized custom ground cam, over the LS9. Remember, the LS9 cam is ground for a smooth idle, emissions, stock exhaust manifolds, and is made to work with a supercharger. There is very little valve overlap. It is NOT ideal for an NA 6.2L with headers, it just happens to produce good peak numbers. You don't need a 20* split between the I/E lobes. Not saying the LS9 is a bad option, its just not the "best" option. For me personally, if I'm going to the trouble of installing a cam, it is going to be exactly what I want.
#65
You just need to have the cam you want ground with the proper advance to work with VVT. It doesn't HAVE to be a specific VVT grind. You advance the cam down low for more power and retard it up high for more power. They key is finding what settings in the tune will yield the best results. If it is a custom cam, you will have to spend time testing at the track or on a dyno.
#67
#69
Nimoryan
Jul 5, 2015 03:50 PM
