Anyone have CalTracs on 1/2T NNBS?
Old Jul 16, 2011 | 01:15 PM
Sheep's Avatar
Default Anyone have CalTracs on 1/2T NNBS?
Has anyone installed CalTracs on your 2wd? I had installed a DJM rear drop, but don't see anyway their bar can be installed.
I have an '11 reg cab shortbed.
If you have installed successfully, what kit part# did you use and what OEM parts did you have to modify if any? Any pic(s) you could post would be helpful.
Thanks, David
Old Jul 16, 2011 | 03:18 PM
LS1TRUCKGUY's Avatar
how did you drop it? flip kit? or hanger/shackle?
Old Jul 17, 2011 | 01:52 AM
tallChevy's Avatar
you need to remove the overload springs then they will fit
Old Jul 18, 2011 | 01:49 PM
Sheep's Avatar
To LS1TRUCKGUY & tallChevy:
Here's pic of the DJM 3" rear drop only, which is combo of shackles and removing block, then flipping the U-bolts. Once you flip the U's upside down, there is no "flat surface" under the axle to mount the back end of a CalTrack. Even if I removed the overload leaf (same situation except truck sits even lower) I'm still stuck with no "flat pad" under the axle to mount a CalTrac even if I install OEM U-bolts.
Since I'm new to susp drops on trucks, particular those with axle under the springs, I need specific help and appreciate all suggestions. Thanks. Searches have not helped.
The righthand pic shows the OEM parts. If you re-install the OEM squared U-bolt with the top plate, you can see the part which the U-bolt clamps against bottom of axle has a curved surface.
UPDATE: Hey guys, just got an answer from Calvert Racing. Their 3400 kit replaces the saddle at the bottom of the OEM squared U-bolt assembly. It still has the saddle to clamp against lower part of axle but has been modified so that their bars work similarly to axle-on-top suspensions. I'll leave the above in case anybody else runs into same question on their NNBS truck. I also ordered the last of 2 pair of their "old style" x9000 rear shocks. The new ones they are bringing out will be more ride-quality oriented rather than drag-oriented. Thanks to you guys who responded.
Old Jul 18, 2011 | 06:06 PM
iamkeniff's Avatar
id like pics of the kit installed please.
Old Jul 18, 2011 | 06:57 PM
dick_landy's Avatar
Sheep, just noticed your sig, have you ran yours at the track?
Old Jul 19, 2011 | 05:17 AM
tallChevy's Avatar
I thought you had the kit already
Old Jul 19, 2011 | 07:53 AM
Robert91RS's Avatar
+1 also interested.
Old Jul 23, 2011 | 09:46 PM
Mang213's Avatar
subscribed!
Old Jul 24, 2011 | 11:15 AM
NKPPhil's Avatar
Hey tallChevy, I can't see your sig for some reason, but just now I finally clicked on the link to see it - Thanks for your Service!
AdaMax
May 16, 2016 11:35 PM
blackedoutchevy22
Oct 1, 2015 08:07 PM
Jr. SXT
Sep 30, 2015 07:23 PM
pewter00
Sep 13, 2015 11:14 AM
02gmc5.3
Sep 7, 2015 08:11 PM
