Adding factory remote start
Old Mar 13, 2013 | 06:59 PM
  #21
When you purchase the remote start dealer installed kit there is also a activation code that is a one time use code and valid only for that time. This code is what allows remote start to be activated in the antitheft module and bcm. That code is given to gm TAC who then adds autostart to your VIN at the factory level not at the dealer level and then the dealer reprograms the bcm and the antitheft module with updated calibrations that allow the autostart to be activated. Then and only then will you have auto start. It's not something you can just take a set of remotes to a dealer and ask them to flash the above modules for autostart.
Old Mar 18, 2013 | 10:29 AM
  #22
a.carey_6's Avatar
Makes sense. I think ill buy it off gm parts direct. People have also been using escalade remotes as well from what I've seen
Old Apr 8, 2013 | 12:29 PM
  #23
RickyMartinZ28's Avatar
I haven't searched much, but can you use the regular or the two-way setup? What's the advantage of the two-way? Didn't know if you needed an entirely different setup for the two-way vs the regular.
Old Apr 9, 2013 | 05:34 PM
  #24
SS94S10's Avatar
You guys should look into the Directed Electronics DBALL from Bypasskit.com
Set it up as a RSR (Remote Start Ready) and done. Remote start for under $100. They also make plug and play harnesses so less splicing. Uses factory remote and just press lock 3 times. No AP8 needed. Set the run time from 1-60 mins. Adjust heated seat intensity and turn on temps. Diesel timers than any aftermarket remote can be added for additional range or a smart start system. Very popular. I work for a dealer and these are more popular. Maybe a little more work to install but very easy and works WAY better. Just my $0.02
Oobray
Jun 13, 2022 03:38 AM
shawn96gmc
May 17, 2016 04:15 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
Ketis
Jul 23, 2015 12:37 PM
