821 vs 823 heads..HELP
Old 02-01-2012, 01:03 AM
62nalide's Avatar
either or, my old cam will fit LS3s and L92s the index card that comp comes in the box says LS3/L92
Old 02-01-2012, 03:09 AM
iamkeniff's Avatar
There is no difference in "cam kits" unless you are buy a roller rocker setup. The 4* split all the way to a 20* split fits the motor. Only issue you have to worry abput is piston to valve clearance the more split you run.
4-8* split unless you plan on running a big converter. BAD *** VHO proves that a 4* split in a Rectangle head runs big numbers and a 222/230 in a 6.0 CCSB runs a 12.78 @ 105 with a lil 278mm 3200
Old 02-01-2012, 08:48 AM
Robert91RS's Avatar
Doesn't really matter. You should replace the springs to match the cam and everything else is the same. Can the seller get you a VIN# or the # etched into the block?
Old 02-01-2012, 08:49 AM
iamkeniff's Avatar
can you get us a picture of the head casting number?
Old 02-01-2012, 09:13 AM
GMCSIERRA5.3's Avatar
on.friday when I get payed imma order a circle d 3600 that big enough or.no?
Old 02-01-2012, 09:14 AM
Ill try n get a pic of the heads in a bit
Old 02-01-2012, 05:16 PM
iamkeniff's Avatar
plenty!
Old 02-01-2012, 06:58 PM
skeet's Avatar
ls3s have sodium filled valves and hollow valve stems
l92s are stainless steele valves
the ls3 has lighter valvetrain <--- thats what you want
Old 02-01-2012, 07:31 PM
thanks skeet and yeah imma go pick it up on.saturday lol good to know its gonna.have ls3 heads lol
Old 02-01-2012, 09:46 PM
62nalide's Avatar
good find and good luck on ur new setup
Quick Reply: 821 vs 823 heads..HELP
